madmike Posted January 14, 2010 Report Share Posted January 14, 2010 Rooooiiight! Needing a new chain and sprocket for the NC29, the only things i can find on the internet are 15F, 39R... But! alot of people have changed there's for various reasons. So is it best to go out and count all the teeth on my sprocket so that i don't mess up my speedo by getting a standard one if it has an aftermarket size on? But saying that... if it had my speedo would be incorrect? There is no way to alter the speedo reading is there? Cheers! Link to comment Share on other sites More sharing options...
cagimaha Posted January 15, 2010 Report Share Posted January 15, 2010 Not 100% sure but I thought the speedo on an NC29 was cable driven from the front wheel. If so then changing the final drive gearing won't affect the speedo reading. If it is an electronic one with a front sproket sensor then the gearing will be affected; if you gear the bike down then it will over-read and vice versa. Just for reference, according to Staniforths the standard sprocket sizes are 15-39 on standard gearing and use a 525x106 chain. Hope this helps, Ben. Link to comment Share on other sites More sharing options...
madmike Posted January 15, 2010 Author Report Share Posted January 15, 2010 ,according to Staniforths the standard sprocket sizes are 15-39 on standard gearing and use a 525x106 chain. Hope this helps, Ben. Noted. Thanks for the help! Link to comment Share on other sites More sharing options...
King_louis Posted January 15, 2010 Report Share Posted January 15, 2010 when i used to have a nc29 i used AFAM for my sprockets, I'm pretty sure bike torque racing are the importers and they were able to provide a range of sizes, they're pretty helpful. With regards to the speedo, the pick up for it is off the front sprocket so you'd need a speedo healer but they are pricey for what they do. I just used to work out the ratio difference and then that gives a percentage increase. From there its pretty easy to work out how far out it will be. Link to comment Share on other sites More sharing options...
SHimmer45 Posted January 15, 2010 Report Share Posted January 15, 2010 speedo is off the front sprocket on the NC23 so i expect the same for the 29. common mod is to put a 14 on the front as it does make a difference, speedo wont be that far out, another 10% was how i roughly worked it out Link to comment Share on other sites More sharing options...
lorenzo Posted January 15, 2010 Report Share Posted January 15, 2010 See if somebody who know has a sat nav you can borrow. Stick it to the tank (clear bag and a load of gaffer will stop them getting pissed off when the sucker comes off) and see how accurate your speedo is at the moment. i bet it's under reading a bit anyway, if you're on stock gearing. Link to comment Share on other sites More sharing options...
madmike Posted January 26, 2010 Author Report Share Posted January 26, 2010 Right, instead of starting a new topic i thought id just bump my old one, Gonna order a new chain and sprocket in the week at somepoint, B&C Express arn't too expensive for renthal sprockets and tsubaki O-Ring chain... Anyone got any recommendations on a good place to get 'em? Cheeers! Link to comment Share on other sites More sharing options...
lorenzo Posted January 27, 2010 Report Share Posted January 27, 2010 Right, instead of starting a new topic i thought id just bump my old one, Gonna order a new chain and sprocket in the week at somepoint, B&C Express arn't too expensive for renthal sprockets and tsubaki O-Ring chain... Anyone got any recommendations on a good place to get 'em? Cheeers! Have you thought about, erm, B&C express? I'm sure that I read somewhere that the renthal sprockets and Tsubaki chain weren't too expensive from them. Incidentally, they do renthal chains there too, anybody tried them? Any good? They're about £20 cheaper than the equivalent Tsubaki. Link to comment Share on other sites More sharing options...
madmike Posted January 27, 2010 Author Report Share Posted January 27, 2010 Have you thought about, erm, B&C express? I'm sure that I read somewhere that the renthal sprockets and Tsubaki chain weren't too expensive from them. Incidentally, they do renthal chains there too, anybody tried them? Any good? They're about £20 cheaper than the equivalent Tsubaki. Yeah B&C Only have Tsubaki chains for the NC29 But... according to Staniforths the standard sprocket sizes are 15-39 on standard gearing and use a 525x106 chain. Hope this helps, Ben. The Tsubaki chain that they sell is size 525x102! What does the 102 part mean? 525AP-102: Tsubaki 525 Alpha O Ring Link to comment Share on other sites More sharing options...
King_louis Posted January 27, 2010 Report Share Posted January 27, 2010 102 links in the chain... Link to comment Share on other sites More sharing options...
madmike Posted January 27, 2010 Author Report Share Posted January 27, 2010 Will it be a problem if I have the standard sprocket sizes with only 102 links in the chain instead of 106? Link to comment Share on other sites More sharing options...
King_louis Posted January 27, 2010 Report Share Posted January 27, 2010 yeah, from memory, with the 106 chain the back wheel was quite far back in the adjusters even when the chain was new.... i don't think it was 4 links worth tho. safer to order the 106 and cut it down of its to long. Link to comment Share on other sites More sharing options...
madmike Posted January 27, 2010 Author Report Share Posted January 27, 2010 Well B&C Only have the 102 link chain! Oh and while i remember... What does the 525 part mean? Link to comment Share on other sites More sharing options...
King_louis Posted January 27, 2010 Report Share Posted January 27, 2010 It refers to the pitch, the distance between the chain rollers. Try Bike torque racing for a chain.. Have you phoned bc and asked them for a 106 or are you just going by the listings online? When i used to work for busters/M+P we used to cut down chains for people if we didn't have the correct size in stock... I'd give them a call. Link to comment Share on other sites More sharing options...
lorenzo Posted January 27, 2010 Report Share Posted January 27, 2010 4 links is a long way. Each link is almost an inch long, so 4 links is probably about 3". I bought a chain last year that was wrongly supplied with 2 links missing and it wouldn't go on, in comparison the correct chain put the adjusters about a third of the way in from the front, so it wasn't as if it was an especially tight fit in the first place. To be honest, as big a pain in the ass as it is, I'd get your bike on a paddock stand, a blob of tippex on the chain at a certain point, and I'd count the links and also the teeth on the sprockets. That way you know what you've got and you can make your judgements about if you want to down gear etc based on how the bike feels at the moment. The 525 bit is a sort of coded bit which'll say how long the gap between links is and how wide each link is. You can get a lighter chain, a 520, and it'll sap less power than spinning round a 525, but the life of the chain'll be lessened. On a day to day bike, I wouldn't bother, the difference I don't think would be especially noticable. Link to comment Share on other sites More sharing options...
