zx6b1h fuelling question
b1h karl
hi, was just wondering if the standard ecu can be adjusted after fitting a can,on occasion since fitting the can usually in 2nd low revs the bike seems to stutter like its dying,pull clutch in and carry on its fine,saying that it did it on standard can too so is it a fuel problem..any help ideas be appreciated
Same as with carbs -there will be take-offs to fit carb balancers/guages to so you can tweek the adjustments. Gatting them all balanced correctly will make a big difference to the general running, and it's more than possible it will cure your probs.
I'd check out the price of a set of vacuum gauges -firstly it's about the most complex bit of kit needed for a basic cervix so your money will be recovered 1st use, and secondly it allows you to double check the settings -on my 9 they really need doing in between the intervals.
Maybe some bike mates have a set? I choose this option as I'm tight.
