Fozzy Posted October 20, 2009 Report Share Posted October 20, 2009 hi can anyone out there tell me if the wheels and discs off a RR5 blade will fit a SP1/SP2 without to much faffing about cheers Link to comment Share on other sites More sharing options...
DocJohn Posted October 20, 2009 Report Share Posted October 20, 2009 hi can anyone out there tell me if the wheels and discs off a RR5 blade will fit a SP1/SP2 without to much faffing about cheers Rear wheel will go straight in if you keep the RR disc, but use the SP sprocket and carrier, and both SP spacers Front is not a straight swop, but can be done with a different hub centre and machined spacers, but I'm not sure exactly (I run an Sp1 rear as a spare in a cbr1000rr) -John Link to comment Share on other sites More sharing options...
Fozzy Posted October 20, 2009 Author Report Share Posted October 20, 2009 Rear wheel will go straight in if you keep the RR disc, but use the SP sprocket and carrier, and both SP spacers Front is not a straight swop, but can be done with a different hub centre and machined spacers, but I'm not sure exactly (I run an Sp1 rear as a spare in a cbr1000rr) -John right thanks for that the thing is i have a rr5 and put PVM wheels in i used to have a sp1 which i miss so want to get rid of the blade for another sp but keep the wheels as they cost 1300 quid Link to comment Share on other sites More sharing options...
lorenzo Posted October 21, 2009 Report Share Posted October 21, 2009 The sp1 front spindle is a funky size and is specific to pretty much sp1's and 2's only, so you'll need, at the least, the spacers and bearings. Link to comment Share on other sites More sharing options...
