Guest bikertiger Posted October 17, 2009 Report Share Posted October 17, 2009 Just having a small issue with the bike When coming off the throttle into a corner. The bike is not loosing any rev’s - Or not quick enough? Meaning, I’m seemingly breaking for the weight of the bike. But also to slow the engine? I’m not looking for engine breaking, or I simply need to use the break more. It just feel ‘slow’ off the throttle At a stand still in Neutral the rev’s raise and fall like feel should. It’s only when racing into a corner where upon the problem occurs?? Hope this makes sense! Link to comment Share on other sites More sharing options...
buster Posted October 17, 2009 Report Share Posted October 17, 2009 Whats your tickover revs? I keep mine about 900-1000rpm, apart from on track where I raise them at least 250-350rpm to lessen the effects of closed throttle (no slipper clutch). If revs to high at tickover gives less engine braking feel when shutting throttle. Link to comment Share on other sites More sharing options...
spacemonkey Posted October 17, 2009 Report Share Posted October 17, 2009 Whats your tickover revs? I keep mine about 900-1000rpm, apart from on track where I raise them at least 250-350rpm to lessen the effects of closed throttle (no slipper clutch). If revs to high at tickover gives less engine braking feel when shutting throttle. It does sound like the tickover is cranked up, maybe because the thing isn't running right at a normal tickover speed? Or maybe the throttle is sticking slightly on the overrun? Link to comment Share on other sites More sharing options...
gregtrx Posted October 17, 2009 Report Share Posted October 17, 2009 I've had this before when I've adjusted all the slack out of my throtle cables.. Link to comment Share on other sites More sharing options...
