steelcat Posted October 10, 2009 Report Share Posted October 10, 2009 I am finally gonnna attempt to change my chain and sprockets on my zx6 tomorrow, and have real a load of horror stories about how difficult is it to undo the bolt on the front sprocket. anybody know how hard it will really be? i know all bikes are a bit different but is it worth me having a go? thanks Link to comment Share on other sites More sharing options...
Tomfoolery Posted October 10, 2009 Report Share Posted October 10, 2009 I've never had a problem and I'm not that much of a mechanic. Breaker bar is handy. Link to comment Share on other sites More sharing options...
tootall Posted October 10, 2009 Report Share Posted October 10, 2009 I've never had a problem and I'm not that much of a mechanic. Breaker bar is handy. Yep them BMW front sprockets are a piece of piss................ Link to comment Share on other sites More sharing options...
Tomfoolery Posted October 10, 2009 Report Share Posted October 10, 2009 Smart arse Link to comment Share on other sites More sharing options...
tootall Posted October 10, 2009 Report Share Posted October 10, 2009 Smart arse Why thank you, its just the way I'm sat though Link to comment Share on other sites More sharing options...
blow_away Posted October 10, 2009 Report Share Posted October 10, 2009 Use a T bar, not a ratchet. Undo the sprocket nut before you remove the chain. If it's really tight, take the bike off the stand and get someone to sit on the bike, put it in first gear and hold the brakes on. If you still can't get enough torque, use a long tube over the T bar. Link to comment Share on other sites More sharing options...
heds954 Posted October 10, 2009 Report Share Posted October 10, 2009 NOTE: Do NOT use a torque wrench for undoing stuff, you'll fuck its accuracy, ok! Link to comment Share on other sites More sharing options...
steelcat Posted October 10, 2009 Author Report Share Posted October 10, 2009 thanks for the help, i have just been to get an old piece of scaffolding that i knew would come in useful one day. hopefully it will be all done and dusted this time tomorrow! Link to comment Share on other sites More sharing options...
lorenzo Posted October 10, 2009 Report Share Posted October 10, 2009 Bar between the spokes of the wheel and the swingarm, wrapped in a towel so it doesn't scratch anything, then a big breaker bar on the front. It's not a techy question you're asking, the answer lies in brute strength... Link to comment Share on other sites More sharing options...
rureadyboots Posted October 10, 2009 Report Share Posted October 10, 2009 Getting the front sprocket off my k2 gsxr 600 beat me and almost beat my mechanic. He needed fire and pneumatic tools. Link to comment Share on other sites More sharing options...
tonk Posted October 10, 2009 Report Share Posted October 10, 2009 Mate has been trying, every so often, to get the front sprocket off his spare Duke for 2 years now. Each attempt sees a bigger bar, last one was a 6 foot scaff pole. Nothing, nada, zip, zero. Think it'll shear the engine mount bolts before it moves. Or he'll sell it... Link to comment Share on other sites More sharing options...
Mr.Pigdog Posted October 11, 2009 Report Share Posted October 11, 2009 Yup certain models of zx6 CAN be a supreme bugger to remove the front sprocket-they have a very deep nut so lots of threads gripping the output shaft-like lorenzo says i use an old fork leg-oxy acetylene is my last resort but it often comes to that,would be better if you could whip off the bellypan etc and just ask a workshop to loosen it for you-then if it goes bad you can blame them!our work impact gun wont do them-usually i sit on the bike in gear with rear wheel locked with bar and brake whilst manager uses breaker bar with forkleg extension.Nasty.dont reckon you'll have good enough access for a big nut splitter-although if im wrong that'll make me even happier! Link to comment Share on other sites More sharing options...
steelcat Posted October 12, 2009 Author Report Share Posted October 12, 2009 A quick update i started the job last night, first problem was i didnt have a long enough 8mm socket to undo the sprocket cover........... a trip to halfords this morning solved that problem. I was thinking that this would be an omen for things to come. Cover undone and wit some apprehension i take a look at the nut of terror. I gather together a number of T bars, sockets and 4 foot scaffold bars to attempt to remove the nut. Only to find that it was less than hand tight. I bends back the washer and it nearly fell off. after the 6 mile round trip to find my grinder, everything went swimmingly. Just hope it all stays together now. Thanks for all your help!!!!!!!!!!! Link to comment Share on other sites More sharing options...
