Stephenrc45 Posted October 12, 2009 Report Share Posted October 12, 2009 For the QB carbon air box I've found the stock needle taper to be better than the dynojet one. Not because the dynojet ones wear the needle tube oval. Needles do that over time anyway. Link to comment Share on other sites More sharing options...
fran9r Posted October 12, 2009 Report Share Posted October 12, 2009 It was only a small number of dynojet needles that were not finished properly and the vast majority of them were for Kawasaki's. I think it was a LOT more widespread than that, but even at that, the needles screwed the carbs on PBs ZX9R (and one of mine) because the needle jets are not replacable. Did dynojet replace the carbs? No. Thats shit. The other crap thing about dynojet is they don't make a jet to fit either Keihin, or Mikuni carbs. Each use different threads, dynojet use one for both. Link to comment Share on other sites More sharing options...
fran9r Posted October 12, 2009 Report Share Posted October 12, 2009 For the QB carbon air box I've found the stock needle taper to be better than the dynojet one. Not because the dynojet ones wear the needle tube oval. Needles do that over time anyway. Agreed they do, but OE would be several thousand miles...I honestly believe the dynojet needles I have are still eating my scrap carbs even without being on a bike. But the taper on the dynojet needles didn't half make the 9R shift above 120. Link to comment Share on other sites More sharing options...
spacemonkey Posted October 13, 2009 Report Share Posted October 13, 2009 It was only a small number of dynojet needles that were not finished properly and the vast majority of them were for Kawasaki's. The dynojet main jets make me laugh.... Made to try and fit the majority of both Keihin and Mikuni carbs but fit neither properly! Link to comment Share on other sites More sharing options...
uggiebear Posted October 14, 2009 Report Share Posted October 14, 2009 Yep ditch the Ais then get the carbs pressurised above and bellow. The old Qb ram air box worked a treat on mine only draw back it drank fuel. the first person to set it up did not get it right and i tinkered after a few times with a lot of help from all over the place. The first dyno reading was 150bhp it started well enough was reliable but drank juice. Another ram air man i know blocked holes up in his carb with no ill effects and it worked fine too! (not sure which ones). Valve timing can make quite a differance with this set up i found so worth dialing them in as well. Is it worth it....Nope. It made a lovely noise though I think spending money elsewhere like suspension would be more worthwhile but if you fancy having a go check out crazy ivan i have been told his needle kit is better and cheaper than Dynojet. Link to comment Share on other sites More sharing options...
foo Posted November 4, 2009 Report Share Posted November 4, 2009 Hey guys, have had an email reply from QB Carbon regarding the Ram Airbox; This the text is sent them; So, have you bought/are you going to buy one of these? I'd be very interested to see how you get on, if you are. From what I remember the glassfibre version of the airbox isn't too expensive, and if it's as good as Mr QB Carbon reckons it is, I might like one myself. Link to comment Share on other sites More sharing options...
rndnick Posted November 5, 2009 Author Report Share Posted November 5, 2009 From what I remember the glassfibre version of the airbox isn't too expensive GRP is £262.12 + VAT Carbon is £299.58 + VAT So not a huge amount of difference in price, havent bought one yet, I think I definetley will do though prob not till after Christmas, as I have just spent all my money on new discs and shiny bolts! Link to comment Share on other sites More sharing options...
sonic Posted November 5, 2009 Report Share Posted November 5, 2009 Some thing to think about before you buy.I had one on my race bike.It was a V&M motor all properly set up and it worked a treat.THEN I fitted Keihen flatslides with no airbox just the foam sock filters and got increases throughout the rev range but mainly topend.Throttle response was excellant though.I would go straight to Keihens if you can.I'll try and find the graphs but sold the bike 12 months ago so may not have them. Link to comment Share on other sites More sharing options...
foo Posted November 5, 2009 Report Share Posted November 5, 2009 GRP is £262.12 + VAT Carbon is £299.58 + VAT So not a huge amount of difference in price, havent bought one yet, I think I definetley will do though prob not till after Christmas, as I have just spent all my money on new discs and shiny bolts! Hmm. So I remembered wrong. No wonder there are copies around if he's charging £300 for a glass fibre airbox. Given what our friend sonic has just said, above, I think I may reconsider this, especially as it seems to be running very nicely on the stock airbox with a high-flow filter and richer jetting. Link to comment Share on other sites More sharing options...
