Brembo reservoir
Number 6
Never seen one
Are you thinking of running brake and clutch from same res.
? wouldnt of thought a good idea. they do do small res think 15mls so easy to tuck away in small spaces ect
Never seen one
Almost, I have a thumb brake on the Katana and I'm looking to tidy up the cockpit area a bit.
I've got a paper-based (how low-tech) catalogue and there's nothing listed, just various sizes of single outlet types.
Might be worth looking at someone that supplies parts for rally/race cars?
G
I too had a look around but found nothing. I think there are some custom aluminium ones around guess it wouldnt be to difficult to weld on onother outlet or maybe try a 2 into one vee piece
Cheers for looking guys, I'd rather not go down the custom ali route if I can help it.
The other option is to use 2 smaller reservoirs piggybacked, I think that could look good as long as they are mounted on a nice bracket.
Sone say dont use the small 15cc res on front brakes ok for clutch though. some say ok for single disc. but not double.
Id consider trying a tee piece so split into two as youd only have one big res to worry about, not that ive done it but hey may work
Remember this isn't a tourer so the chances of me using up enough pad to displace 15ml of fluid on one of my rides is pretty remote (no pun intended)
T piece might work but be a bit untidy, I'll keep searching for now.
Or maybe make up a bracket to carry a small and large res together, if done right that could look fairly trick.
I'd get a single large ally one and then weld a new outlet to it, although gawd only knows what sort of quality the metal is that they're made out of.
Why not a clutch with an integral res (square black) and a remote res for the thumb brake.
I have a thumb brake and cable clutch so wanted to run one res up front for front brake and rear.
I managed to get a res with 2 outlets from Silverstone today when I was over there, genuine Brembo item for a fiver, only trouble is there is no mounting lug so I'll have to get creative on a bracket.
