beek Posted September 8, 2009 Report Share Posted September 8, 2009 Is a rear shock hose the same as brake hoses as i was told its a differnt bore and fittings. though they look alike. also where can i get a new hose make for rear shock. Link to comment Share on other sites More sharing options...
si.likes.guiness Posted September 8, 2009 Report Share Posted September 8, 2009 try HEL lines mate,they may be able to knock you summat up Link to comment Share on other sites More sharing options...
lorenzo Posted September 8, 2009 Report Share Posted September 8, 2009 Fittings are the same, but I'm not sure about bore. Link to comment Share on other sites More sharing options...
beek Posted September 8, 2009 Author Report Share Posted September 8, 2009 Cheers for info. ive email HEL to see what they say. I think your right lorenzo the fitting look identicle to brake fittings and actually bolt on ok too. Its a pain really as need a longer hose as remote needs to be in a different position Link to comment Share on other sites More sharing options...
blow_away Posted September 9, 2009 Report Share Posted September 9, 2009 I'm pretty sure that shock hoses have a much larger internal bore than brake hoses. See what HEL say, or try someone like Pirtek TAKE CARE - the oil in the shock chamber is pressurised. If you are not sure what you are doing, leave well alone and send it to a specialist. Link to comment Share on other sites More sharing options...
lorenzo Posted September 9, 2009 Report Share Posted September 9, 2009 Take a look in the team north bros thread, there's a whole bit in there about butchering/rebuilding a shock. Link to comment Share on other sites More sharing options...
johnnymack63 Posted September 15, 2009 Report Share Posted September 15, 2009 Contact Nitron Shocks 01993-849449 Quality kit, really brainy staff and helpfull too. I'm sure not only would they supply the hose but they'd probably fit it for you too. Link to comment Share on other sites More sharing options...
eddie Posted September 15, 2009 Report Share Posted September 15, 2009 Hi Jason, I've used MH Racing in the past, in Wiltshire (not too far from you) He's pretty good. (If he's still going) Paul Link to comment Share on other sites More sharing options...
beek Posted September 15, 2009 Author Report Share Posted September 15, 2009 Hi Jason, I've used MH Racing in the past, in Wiltshire (not too far from you) He's pretty good. (If he's still going) Paul Link to comment Share on other sites More sharing options...
