widdy Posted August 26, 2009 Report Share Posted August 26, 2009 Hi peeps, anyone ever done their own homebrew turbo convertion? i seem to remember renault 5 turbo's where popular at one point. and was the pain worth it ? ok here are some specifics for those inclined- i've got an ace (keeps up with rc8's ) and was thinking of chopping it in for a zzr to play with but then though about the turbo option. exhaust manifold- how crutial are the individual pipe lengths etc and how difficult to manafacture exhaust outlet- dump pipe only or repiped back through a silencer and the implications of each intercooling, etc it's not about outright speed but about haveing something a wee bit different Link to comment Share on other sites More sharing options...
diogo Posted August 26, 2009 Report Share Posted August 26, 2009 it depends on wich bike, if it has carbs (and wich ones CRs, CVs, etc) throttle boddies, mitsubishi TD04 tends to be pretty popular among home built kits, you can find a donour in a uno turbo i.e. for the smallest and in volvo's T4 and T5 and mitsubishi lancer evo if you want a bigger one, you need to custom make a plenum for the intake system, fuel pump, lower compression etc etc it's all a bit vague without knowing what you plan on doing...:S Link to comment Share on other sites More sharing options...
711tattoo Posted August 26, 2009 Report Share Posted August 26, 2009 there is a turbo section on oldskoolsuzuki lots of info there Link to comment Share on other sites More sharing options...
Tomfoolery Posted August 26, 2009 Report Share Posted August 26, 2009 Calling Gray01... Link to comment Share on other sites More sharing options...
diogo Posted August 26, 2009 Report Share Posted August 26, 2009 there is a turbo section on oldskoolsuzuki lots of info there indeed Link to comment Share on other sites More sharing options...
widdy Posted August 26, 2009 Author Report Share Posted August 26, 2009 that would be under "Forced induction" then cheers lads Link to comment Share on other sites More sharing options...
xtmito Posted August 26, 2009 Report Share Posted August 26, 2009 i have built a few car engines turbo'd and supercharged on a low budget. they are pretty simple but there are a few fundemental things they need. yep the renault5 turbo (Garett T2) is popular there are so many cars to rob bits from try to stick to petrol engine'd cars as the ar ratio of the turbo's are better. The main thing is if running carbs you will need a rising rate fuel pressure regulator to keep it above boost pressure. (other wise fuel goes the wrong way) carbs need to be sealed some need spindle seals fitting. and there is a thing calles a restrictor ring in the plenum which will need figuring out but there is info over the web. mechanically ie lower compression ratio needs sorting in some way piston or thick head gasket etc any questions post and i will help if i can Link to comment Share on other sites More sharing options...
widdy Posted September 1, 2009 Author Report Share Posted September 1, 2009 i have built a few car engines turbo'd and supercharged on a low budget. they are pretty simple but there are a few fundemental things they need. yep the renault5 turbo (Garett T2) is popular there are so many cars to rob bits from try to stick to petrol engine'd cars as the ar ratio of the turbo's are better. The main thing is if running carbs you will need a rising rate fuel pressure regulator to keep it above boost pressure. (other wise fuel goes the wrong way) carbs need to be sealed some need spindle seals fitting. and there is a thing calles a restrictor ring in the plenum which will need figuring out but there is info over the web. mechanically ie lower compression ratio needs sorting in some way piston or thick head gasket etc any questions post and i will help if i can Thanks for the offer of help XTmito, no doubt i will be e-mithering you at some point with a daft question Link to comment Share on other sites More sharing options...
xtmito Posted September 3, 2009 Report Share Posted September 3, 2009 No prob i have been thinking of a turbo project and just so happens got given an engine that is just begging for it Link to comment Share on other sites More sharing options...
