Engine cut-out
DAMO666
Just been getting my 89 FZR1000 exup ready for the MOT.Engine starts fine hot or cold but when you put it in gear it stalls, I've checked the clutch and side stand switches both fine with the multi meter. Is there any other safety cut-outs that i need to check, is the large relay unit behind the side panel just for the starter circuit or could this be causing it.
Getting a tad vexed now wanted to get it tested this week.
A mate of mine had this exact same problem on an RGV. Turned out a fuse had popped. Cheap fixes are great.
