Bannon_Orcus Posted June 24, 2009 Report Share Posted June 24, 2009 Ok gang, here is my H1 > ZX7r fork mod. A great mod offering trick looks and better brakes. Plenty more projects where that came from. Link to comment Share on other sites More sharing options...
Rompy McPoot Posted June 24, 2009 Report Share Posted June 24, 2009 Bloody Nora, matey! Them's some top pics! You've put a lot of work just into the tutorial, so I'm not surprised the swap worked! Smart work! Link to comment Share on other sites More sharing options...
Ascalon Posted June 25, 2009 Report Share Posted June 25, 2009 Yeah, Kudos there mate, welld one and well documented. There's extra points for showing your work, y'know! Nice! A Link to comment Share on other sites More sharing options...
Bannon_Orcus Posted June 25, 2009 Author Report Share Posted June 25, 2009 Thanks Both, I was a very good project. The end result is very pleasing. As she stops well into the bargain. Expecting to put Suzuki calipers on next....for that extra power. I also have a Brembo Radial master cylinder on the way, so I should be able to stop on a penny! I need a close ratio gearbox however....so the search continues. Link to comment Share on other sites More sharing options...
Agtrak100 Posted August 18, 2009 Report Share Posted August 18, 2009 Thanks Both, I was a very good project. The end result is very pleasing. As she stops well into the bargain. Expecting to put Suzuki calipers on next....for that extra power. I also have a Brembo Radial master cylinder on the way, so I should be able to stop on a penny! I need a close ratio gearbox however....so the search continues. Any chance of a side on pic of the bike on its' stand???? looks real nice..... jobs' a good 'un SteveT RHRC Link to comment Share on other sites More sharing options...
nzknut Posted March 18, 2010 Report Share Posted March 18, 2010 hi - how different is a ZXR400 front end to the ZX7R? Link to comment Share on other sites More sharing options...
ZXRRDave Posted March 19, 2010 Report Share Posted March 19, 2010 hi - how different is a ZXR400 front end to the ZX7R? Much shorter and lighter - but may be too short fork length wise - I have just put a 7R front end on my H1 using this guide and it has dropped the front end a bit, so you wouldnt really want to go any lower. Link to comment Share on other sites More sharing options...
nzknut Posted March 19, 2010 Report Share Posted March 19, 2010 Much shorter and lighter - but may be too short fork length wise - I have just put a 7R front end on my H1 using this guide and it has dropped the front end a bit, so you wouldnt really want to go any lower. ah cheers man - scoping out an original but kinda rough zxr750 H1, and was looking for quiet/cheap mods.. how do they run with the 170 section rear tyre, and are tyres hard to find? if i buy it i will have owned every 1989 ZXR... the 250, the 400 and the 750.. Link to comment Share on other sites More sharing options...
ZXRRDave Posted March 19, 2010 Report Share Posted March 19, 2010 ah cheers man - scoping out an original but kinda rough zxr750 H1, and was looking for quiet/cheap mods.. how do they run with the 170 section rear tyre, and are tyres hard to find? if i buy it i will have owned every 1989 ZXR... the 250, the 400 and the 750.. H model ZXR's run 180's - the first mass produced sportsbike to do so I beleive. All the TB guys certainly run 180 slicks. 5.5" rims all through the ZXR750 range. Link to comment Share on other sites More sharing options...
nzknut Posted March 19, 2010 Report Share Posted March 19, 2010 mint - its heading to winter over here, probabaly going to run med comp race wets on the road if i have the $$ Link to comment Share on other sites More sharing options...
trebup Posted June 4, 2011 Report Share Posted June 4, 2011 Hiya, whats involved(difficulty level)in removing stem without knackering bottom yoke? Bearing press a pre-requisite I assume? Link to comment Share on other sites More sharing options...
ZXRRDave Posted June 4, 2011 Report Share Posted June 4, 2011 Hiya, whats involved(difficulty level)in removing stem without knackering bottom yoke? Bearing press a pre-requisite I assume? That's what the guy who sorted mine for me used. Fairly solid fit too. Link to comment Share on other sites More sharing options...
